  • 5 Vote(s) - 2.6 Average
non starter
Hi all. Newbie here. I got a 1.4 lpg which has been standing since before christmas. It was totally fine then. But now it wont start. The fuel pump isnt priming and there is no voltage to the coil pack. could it be a relay? Thanks in advance
Is it recognising the key (is there a credit-card-with-key-inside symbol remaining lit on the dash)?
No thats not showing
Next thing to suspect would be a fuse - check them all, then check the large black or brown double relay located in the engine compartment near the ECU box.
Have checked the fuses. Could do with knowing which fuse did what. Will have a look for that relay when i get home from work.
There isnt a relay by the ecu
Where else could this relay be. Could do with a wiring diagram. Its a y reg 1.4
Oh man this is gettin on my nerves now. why not start all ov a sudden. Might just set it on fire lol
(05-02-2013, 12:39 PM)coxxyukf Wrote:  Oh man this is gettin on my nerves now. why not start all ov a sudden. Might just set it on fire lol
Hey non starter
no setting on fire dude :eek:.. maybe you should hire a professional for that. Its getting serious and maybe that professional can help you fix that problem Wink just a suggestion
(06-02-2013, 08:24 AM)Jessie23 Wrote:  Hey non starter
Well that attitude seems to undermine the purpose of these forums more than a little. We could all take our cars to 'professionals' every time we needed a job done.....and I think that the OP came to us to find out if we could help......it takes no brains to send him to the local garage. Rolleyes
Just need to find the relay and i should be good to go
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
