Threads: 16
Thanks Received: 1 in 1 posts
Thanks Given: 1
my mark 1 berlingo cut out on me this afternoon, and wouldnt re-start.now when you attempt to start, the alarm sounds, and alarm icon appears on the dashboard. on further inspection it had blown a fuse, but when this fuse is replaced, it simply blows again, and the vehicle refuses to start, anyone any idea as to what the problem could be?
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
If you could let us know which fuse in which fuse box it might help us to find your problem. petrol or diesel?
Threads: 16
Thanks Given: 1
its a 20 amp fuse, halfway down fusebox on the right , underneath the sterring wheel, sorry i cant be more specific, as casing is missing-must be related to ignition, as when this is replaced, engine starts for a short while, then blows it again
Threads: 67
Thanks Given: 1,045
It's a big difference between mux and non-mux cars. What is the RPO (five digit number on the door jamb sticker)?
Threads: 16
Thanks Given: 1
update on ignition problem, car started ok this morning with fuse replaced, and ran for 3 miles with no problems, went through some deep water yesterday so maybe it was causing fusing problem! when ignition switch is turned off, there are 3 double beeps, does anyone know if this is a fault code? again, many thanks for all your help
