  • 10 Vote(s) - 2.7 Average
my bingo is a bit sick
o dear my berlingo ( 03 2.o forte 46K owned from new)failed its mot today, front coil spring and rear exhaust box. so i the mech asked to chage the spring i of course gave the go ahead but i'm thinking now maybe they should be changing both. he did say just that one side failed.
is their a safty implication here, they have quoted £207 for mot for the work and parts inc vat
is this ok ?
When one spring failed on mine, I changed them both, but it's not really needed, I changed both as I didn't want to run the risk of the other failing, I think the springs were about £35 each and took me probably an hour each side to do.
£207 doesn't seem bad to me.
[-] The following 1 user says Thank You to steve valentine for this post:
  • goa55
That is a good price for the works, i'd only change the broken spring too.
This does seem to be the year for the back box on 03 berlingos to finally give up though.....??
The new design is a lot neater with a shorter pipe.
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • goa55
Hi guys,
I think its probably prudent to change both as general thinking is that any new spring will tend to wear at a greater rate than it would if a pair were changed. This is due to excess 'demand' being placed on the stronger spring. It also ensures better stability if both are renewed. Eventualy they get to the same state of wear and need replacing together (old and new)!
Always seems a bit of an economic nonsence to replace an apparently good spring but in the long run?
Regards, El Berlingo
[-] The following 1 user says Thank You to El Berlingo for this post:
  • goa55
thanks for the replies
[-] The following 1 user says Thank You to goa55 for this post:
  • adam3rdcanvey
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
