  • 9 Vote(s) - 2.67 Average
engine hunting
got this silly problem now and again my engine will start hunting when cold the revs bounce between 500 and 1000 rpm some times it'll stall and we need to keep the throttle peddle down a little to keep the revs up
the car is a 2000 reg 1.4 petrol 53k miles
any idea's
Thanks in Advance
Plugs changed recently?
(06-02-2013, 06:42 PM)corkgsxr Wrote:  Plugs changed recently?
just serviced before i bought it ???
I had a similar problem not with a Citroen though. It was the throttle position sensor.
(06-02-2013, 08:51 PM)ffrenchie Wrote:  I had a similar problem not with a Citroen though. It was the throttle position sensor.
did it require replacing or is it a serviceable item ??
Id change the plugs too. Serviced before you got it means it got a oil and filter before you got it.
Happens my gsxr when the iridium plugs wear out
i'll get a new set of plugs tomorrow get them fitted by the weekend
Yes, it was only a few quid and held in place with two screws. You can test them with a meter, they are just a linear potentiometer. I don't know the measurements but someone should have them somewhere.
Rear light cluster removal
Last Post: phydaux
Yesterday 11:47 AM
Cranks but won't start
Last Post: MarkA67
Yesterday 10:45 AM
Last Post: BrianS
Yesterday 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
17-11-2025 10:07 PM
Engine Fan Running
17-11-2025 09:59 PM
Bettery Issues - A Solution.
17-11-2025 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
