  • 7 Vote(s) - 2.57 Average
DIESEL MISSFIRE ???
HI , MY 2005 2.0 HDI BERLINGO HAS STARTED TO WHAT FEELS LIKE A MISS FIRE @1500 - 1750 RPM , ANY IDEAS WHAT THE PROBLEM COULD BE ?
What do the fault codes say?
I HAVE NOT HAD IT PLUGGED IN TO A READER YET ! I HAVE HAD THE TOP COVER OFF AND THE CRANK POSITION SENSER LOOKS DAMAGED AS IT HELD TOGETHER WITH A CABLE TIE !
Try that then, seeing as thats what jumps out at you, and lose the caps lock, there's a good chap
[-] The following 1 user says Thank You to steve valentine for this post:
  • ron
Watching this with interest, same with mine.
please keep us up to date on your findings.
i had this,check the seal in the top of the fuel filter if its the siemens,if its a poor seal it will draw in air and thus misfire.you can see the air in the pipes as you rev the engine.hope this helps
[-] The following 2 users say Thank You to lorraine for this post:
  • ron, royboy302
I brought a fault code reader and it shows no faults , I changed the camshaft and crankshaft sensors , I have left it running and kept an eye on the clear diesel pipes to see if any air is being drawn in , but nothing ! I took it out for a drive and its still missing at 1500 -1750 rpm ! Not happy !!!!!
Mine did the same. My Kia Sedona does it too.
Sent from my ST21i using Tapatalk 2
I have ordered a tuning box from tdi tuning and a new fuel filter , just to see if that might help !:brickwall:
up date on running problem ! Got my tuning box , went to fit it and it would not work , so i rang the helpful people at tdi tuning and after some pictures and a chat with on of their engineers it turned out that the bosch plate on the common rail is only there because people like bosch not seimans ??? so new loom is on its way !! Smile
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
