Battery quick release loose
Threads: 24
Thanks Received: 52 in 44 posts
Thanks Given: 9
Hi all,
how do I tighten the positive, quick release connector? When done up, I can rotate connector on battery terminal. That can't be good. Bingo starts OK, but sometimes take a few more turns than I would like. I can't see a bolt to tighten in the clamp. It's possible that this, fairly new, battery has slightly smaller terminal than original, but you should be able to adjust it.
Threads: 78
Thanks Received: 363 in 306 posts
Thanks Given: 159
9
It needs sorting pretty quickly - On lorries where two batteries are linked the cranking current can zap a terminal if the the clamp is loose.
It sounds like the other size connector has been used on your positive wire,or someones gone mad with a terminal restoring die and reduced the size.
For the moment I would pack out part of the clamp with some metallic material until its tight.
You can get replacements cheaply http://www.ebay.co.uk/sch/i.html?_nkw=qu...9084363586 or similar.
Ive had a set of the red/blue ones on my tractor for a few years and they work superbly despite the low price
• ron
Threads: 24
Thanks Given: 9
(09-02-2013, 05:31 PM)evdama Wrote: It needs sorting pretty quickly - On lorries where two batteries are linked the cranking current can zap a terminal if the the clamp is loose.
Ive had a set of the red/blue ones on my tractor for a few years and they work superbly despite the low price Ta for that. Would have thought it would be the negative that was quick release, as this is supposed to be removed first ??
Threads: 78
Thanks Given: 159
9
(09-02-2013, 05:46 PM)Modmytop Wrote: (09-02-2013, 05:31 PM)evdama Wrote: It needs sorting pretty quickly - On lorries where two batteries are linked the cranking current can zap a terminal if the the clamp is loose.
Ive had a set of the red/blue ones on my tractor for a few years and they work superbly despite the low price Ta for that. Would have thought it would be the negative that was quick release, as this is supposed to be removed first ?? Whatever the politics it needs securing :lol:
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
09-02-2013, 07:29 PM
(This post was last modified: 10-02-2013, 11:31 AM by Ol'Jeffers.)
Nip into Hellfrauds and get a complete new terminated lead. Loose battery terminal connectors are very bad news!
If this goes pear-shaped you could end up buying a new battery and /or causing other expensive damage.
Keep the original for another new battery or for posterity!
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
Is the connector pushed all the way down ? I fitted a new battery and the connector was loose at first because it was near the top of the terminal and it tapered at the top. I flipped the lever up, pushed down on the connector and seated it firmly lower down and it's been sound since.
Threads: 24
Thanks Given: 9
(09-02-2013, 08:07 PM)ffrenchie Wrote: Is the connector pushed all the way down ? I fitted a new battery and the connector was loose at first because it was near the top of the terminal and it tapered at the top. I flipped the lever up, pushed down on the connector and seated it firmly lower down and it's been sound since. Yeah, I checked it was all the way down. To be honest I fitted the new battery, must be a year ago. No real problems starts OK etc. Only recently chasing an airbag light problem, hence disconnecting/reconnecting batt I noticed it. Can't believe the clamp has no adjustment in it. I had a look, but without taking the grease off it I couldn't see any bolt/nut to adjust.
Threads: 63
Thanks Given: 410
Of crappy poor construction. Bought two new lugs for mine + & -ve hoping to just bolt leads on but not quite that easy. Some leads attached to 8mm stud on lug but the main lead from battery to starter has original Q/R lug crimped to it so can't just unscrew and replace.
Modymytop, yes I was always taught to remove -ve lead first for safety reasons, definately +ve lead with quick release on the 'lingo, typical arse uppards electrics...
Threads: 24
Thanks Given: 9
(10-02-2013, 10:37 AM)andy-womble Wrote: Of crappy poor construction. Bought two new lugs for mine + & -ve hoping to just bolt leads on but not quite that easy. Some leads attached to 8mm stud on lug but the main lead from battery to starter has original Q/R lug crimped to it so can't just unscrew and replace.
Modymytop, yes I was always taught to remove -ve lead first for safety reasons, definately +ve lead with quick release on the 'lingo, typical arse uppards electrics... Only thing I could think is that with quick release, you won't be using spanner to undo terminal, and hence can't short +ve to chassis.
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 09:44 PM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Last Post: paulod
Yesterday 12:05 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
