Threads: 10
Thanks Received: 15 in 9 posts
Thanks Given: 1
Mk 3 2011
front sidelights and headlight bulbs keep blowing every three weeks or so, I run with headlights on so expect early failure but three weeks is a bit much.
Anyone else suffer this problem?
K9 XL Driver 130EAT8 2024 94k Dec25
Threads: 67
Thanks Given: 1,045
Have you checked your charging voltage, and voltage at the headlamps themselves?
Threads: 52
Thanks Given: 87
5
There had been a thread on berlingo.org about the same problem. Solution was to turn on lights only after starting engine. Was down to a voltage spike.
Threads: 29
Thanks Given: 67
20
(10-02-2013, 10:03 AM)mrbritse Wrote: I may have this problem, but only with the sidelight. I turn them on when the engine is running but have noticed the indicator on that side (only) flashes once sometimes, not everytime, as I turn them on. The bulb hasnt blown for a while so I have decided that it is just a quirk. Anyone else noticed this?
illyme: On your cars not mine!
Have you got a towbar fitted ? My car doesn't do it but a friend's Land Rover had the same symptoms and it was water getting in the towing electric socket and messing the earth up. Check the indicator when the brake is pressed as well, when the indicator and brake were used together it flashed all the lights dimly.
Threads: 10
Thanks Given: 1
10-02-2013, 10:24 PM
(This post was last modified: 10-02-2013, 10:29 PM by chrisl.)
Thanks Chaps, I always leave the lights on and never switch off at the end of the day,I will make sure I remember to turn them off at the end of the day.
will report back in a week or so !
Have to admit that I have not checked voltages .... yet !
(10-02-2013, 10:24 PM)chrisl Wrote: Thanks Chaps, I always leave the lights on and never switch off at the end of the day,I will make sure I remember to turn them off at the end of the day.
No towbar fitted either !
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
This is good advice for those of us who get through quantities of Nightbreakers and Ring Ultimas.
Its conveniant for me to leave them switched on as I rarely drive in full daylight- didnt occour to me with the voltage spike although its perfectly logical.
