07-03-2011, 10:52 PM
(This post was last modified: 07-03-2011, 11:15 PM by adam3rdcanvey.)
Below is a list of all recall items from citroen. Could be of use to those with part service history. Worth checking your VIN?
Recall History of Citroen Berlingo (1998 - Present):
Date Model Recall
01 Feb 2000 Built: 01/09/1999 - 31/10/1999 There is a possibility that the brake servo valve may not function correctly, resulting in loss of servo assistance to the braking system.
16 May 2005 Built: 01/07/2004 - 30/09/2004 The air bag control unit may be underestimating the significance of an impact for the purposes of deploying the airbags. VINs: VV7******94002400 to VF7******94142908.
13 Jul 2005 Built: 01/12/2002 - 30/09/2003 In the exceptional event of a spring breaking there could be a risk of the spring making contact with the vehicle tyre. VINs: VF700000094000192 to VF700000094068124 VF700000093006682 to VF700000093100993 VF700000036624276 to VF700000039623407
13 Jul 2005 VINs: 01/06/1999 - 30/09/2002 In the exceptional event of a spring breaking there could be a risk of the spring making contact with the vehicle tyre. VINs: VF700000065335197 to VF700000065895578 VF700000094000175 to VF700000094064754
Recall: No. 4 of 11
Recall Ref: R/2005/097
Exact Model: Berlingo Berlingo electric
Description: Suspension springs may break
VIN: Berlingo VF700000065335197 to VF700000065895578, Berlingo Electric VF700000094000175 to VF700000094064754
Build Date:
Numbers: 50357
Defect: In the exceptional event of a spring breaking, there could be a risk of the spring making contact with the vehicle tyre.
Action: Recall the vehicles that are likely to be affected and fit a suspension cup to each side of the front suspension.
Launch Date: 13 July 2005
Recall: No. 5 of 11
Recall Ref: R/2009/099
Exact Model: Berlingo, Xsara, Picasso
Description: REAR DAMPER MAY BECOME INSECURE
VIN: VF7******9J087225 to VF7******9N013700
Build Date:
Numbers: 54
Defect: The rear dampers lower fixing bolts may become loose.
Action: Recall affected vehicles to check conformity of damper lower fixing bolt and replace if necessary
Launch Date: 09 October 2009
Recall: No. 6 of 11
Recall Ref: R/2008/096
Exact Model: Berllingo
Description: Wipers, lights and battery charging may be affected
VIN: VF7******67000658 to VF7******6760135
Build Date:
Numbers: 45
Defect: It has been identified that one component of the computer that controls the operation of the wipers, lighting, and battery charging is not to specification. This can result in erratic operation or failure of one or all of the specified functions.
Action: recalled vehicles will have the subject computer replaced
Launch Date: 03 July 2008
Recall: No. 7 of 11
Recall Ref: R/2008/199
Exact Model: C4 Picasso, C2,C3, C3 Pluriel, C4, C5,C6 and Berlingo
Description: WIPERS / LIGHTS/ BATTERY CHARGING MAY BE AFFECTED.
VIN: VF7******67002101 to VF7******45299702
Build Date: 1/2/08 to 14/6/08
Numbers: 6031
Defect: An incorrect engine relay unit may have been fitted. This ECU could deteriorate and cause operating faults and perhaps failure of certain equipment
Action: Recall affected vehicles, check Engine Relay Unit and replace if not correct specification.
Launch Date: 24 December 2008
none for 07 yet
will keep trawling through the records though
Date Model Recall
Recall: No. 4 of 11
Build Date:
Numbers: 50357
Recall: No. 5 of 11
Build Date:
Numbers: 54
Recall: No. 6 of 11
Build Date:
Numbers: 45
Recall: No. 7 of 11
Numbers: 6031
none for 07 yet
