  • 16 Vote(s) - 3 Average
Tyre wrench
Replaced a tyre yesterday and the tyre wrench has gone out of shape a little so doesn't grip the bolt and I end up flying. Anyone got any ideas for a good replacement or if possible another berlingo one? Couldn't find a berlingo tyre wrench on eBay
Lliam
70 plate Berlingo
I use one of those extending ones like this on ebay;
http://cgi.ebay.co.uk/Tyre-Wrench-Telesc..._500wt_922
Plenty of leverage.
[-] The following 1 user says Thank You to steve valentine for this post:
  • lemsworld
Any size 17 bolt with a good leaver to attach it to!
[-] The following 1 user says Thank You to Andre for this post:
  • lemsworld
I did see telescopic ones but was wary they may not be so solid. How good/strong are they?
Lliam
70 plate Berlingo
(26-03-2011, 04:05 PM)lemsworld Wrote:  I did see telescopic ones but was wary they may not be so solid. How good/strong are they?
Had mine about 6 years or so, still going strong, on stubborn nuts ( after tyre monkeys have used the air hammer on them ) I've stood on it Big Grin
Will try one of these then, was it at the same price as eBay or a more expensive one though?
Thank you
Lliam
70 plate Berlingo
Is there a specified torque for wheel bolts or is it the old "snug it up and then hit the wrench with your palm*. Myself, I've always used the latter method and never had a problem.
(26-03-2011, 05:06 PM)3rensho Wrote:  Is there a specified torque for wheel bolts or is it the old "snug it up and then hit the wrench with your palm*. Myself, I've always used the latter method and never had a problem.
When I worked as a plant fitter for the NCB (Coal Board), the torque setting we used was "Tighten until the thread strips, then back off half-a-turn"Big GrinBig GrinBig GrinBig Grin
Back to business, I use an 18" power-bar similar to this with 17mm 1/2" drive socket http://cgi.ebay.co.uk/1-2-BREAKER-BAR-PO...3365d6d789
If you are buying one, make sure you get a good quality one and it will last you, bought mine when I was an apprentice back in 1973 used in industrial environment and still going strong. Make is Elora, don't think you can still get that make anymore but any good make such as Snap-On (expensive), Britool etc.
Hi,
The ebay wrench quoted by Steve Valentine looks very similar to the wrench/s that we have used for the past 20 years or so without problem.
However, we are on our second wrench as the first one was lent out but as seems to be normal wasn't able to find its way back to us.
As the wrench has the normal half inch square it becomes very useful for dealing with stubborn nuts etc - extra leverage over the standard socket set wrench. Be wary about using it to tighten nuts though!
Best wishes,
Jim & Tracey
  Berlingo XTR HDi110, Tivoli Blue, Modutop, MyWay etc etc
(26-03-2011, 05:21 PM)andy-womble Wrote:  If you are buying one, make sure you get a good quality one and it will last you, bought mine when I was an apprentice back in 1973 used in industrial environment and still going strong. Make is Elora, don't think you can still get that make anymore but any good make such as Snap-On (expensive), Britool etc.
34 years old! I didn't think people kept things for that long, regardless if they worked or not!
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
