  • 4 Vote(s) - 2.75 Average
dies when slowing down
:brickwall: 56 plate 1.9 mine can rev high and come down slowly which i can cope with but mainly when i slow down it has a tendency to die but will restart off the key can also kangaroo a bit ,please help
[-] The following 1 user says Thank You to rottyno1 for this post:
  • taxi
Are the air & fuel filters OK?
all new
(11-02-2013, 10:22 PM)ron Wrote:  Are the air & fuel filters OK?
all new thanks
Try running a GOOD fuel system cleaner through it.
ive done redex
(11-02-2013, 10:29 PM)ron Wrote:  Try running a GOOD fuel system cleaner through it.
ive tried redex twice
(11-02-2013, 10:30 PM)rottyno1 Wrote:  ive done redex
All well & good but you need to make it work without thrashing it.
Run it with a double dose of Millers in the tank. If that makes no difference
I would think that you have a problem with the fuel system.
(12-02-2013, 02:10 PM)OlJeffers Wrote:  Run it with a double dose of Millers in the tank. If that makes no difference
+ 1 on the millers
i had a mondeo for a short time (bag of sh1t) and the only way to stop the injectors knocking and the thing kanging on over run was to use millers at x2 dosage.
i always use the stuff in all my motors now - more mpg and runs smoother - but this may just be my imagination :whistle:
(11-02-2013, 10:26 PM)rottyno1 Wrote:  all new there is air in the pipes both sides of the pump and ive tried priming it ..doin my head in
all new thanks
Check the flexible fuel pipes for dampness. They can break down/decompose & let air into the system.Go back to the tank,not just the engine bay.
I'm not a fan of Redex.Millers or Forte really work.Millers for constant use & Forte for deep cleaning(not necessary if Millers is used regularly)
Last Post: BDRichardson
Today 04:07 PM
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
