Threads: 5
Thanks Received: 2 in 1 posts
Thanks Given: 6
Thanks to the previous owner..What i dont understand is, that when i fitted a new one, the performance got worse..wont rev over 2000rpm, like its being restricted?
Threads: 29
Thanks Given: 67
20
It's got used to being strangled, you'll have to wean it by using gradually cleaner filters or it will go cold turkey
Sorry not to be constructive but I would look at the MAF sensor now you've swapped the filter.
Threads: 5
Thanks Given: 6
11-02-2013, 11:38 PM
(This post was last modified: 11-02-2013, 11:39 PM by BrookWCServices.)
I thought something like that myself, ive had the MAF off and cleaned it using MAF cleaner. After reading on here i thought it would work, but no, still the same, maybe its a faulty MAF and now it has a better flow of air its causing this? The air filter housing wasnt secured properly either, the pipe leading from the front of the van wasnt meeting it so it was sucking air from the bottom of the van.
so should i put the dirty filter back in to see what happens?
Threads: 32
Thanks Given: 24
12-02-2013, 08:36 AM
(This post was last modified: 12-02-2013, 08:37 AM by Coco.)
MIL light on?
Do you know someone with a code reader?
Try starting it then switching off, removing the key and waiting thirty seconds then restart. Repeat this 5 times
Threads: 15
Thanks Received: 8 in 5 posts
Thanks Given: 14
Pulled one out of my multispace in a very similar condition, the airbox was also full of rotten foliage, oil and various dead wildlife... I think the previous owner was trying to make his own petrol in there! :S
