  • 12 Vote(s) - 2.5 Average
Berlingo abs problems
:brickwall: Hi everyone...i have problem with my berlingo,abs is playing up cus no reluctor ring on L/H driveshaft...im having new driveshaft fitted in 2 weeks but need v van for work so want to disable abs till then....i tried taking the abs fuse3 out in engine bay but stop lamp kept flashing.......is there another way to disable abs so i get normal braking......berlingo 600 van 1.6 hdi 2007....any advice is appreciated......thanx...........
I think not. The ECU will know that there is a brake problem and
you might find yourself in limp mode quite shortly.
sliding door panel removal
Last Post: mojito
23-03-2025 07:35 PM
XL tyres
23-03-2025 06:57 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
