  • 8 Vote(s) - 2.25 Average
Side Steps
Does anyone know of a supplier for side step for the MK3 Berlingo ?
My wife is disabled & a side step would make getting into the car much easier. Smile
Check out http://www.tradevanaccessories.co.uk
[-] The following 1 user says Thank You to taxi for this post:
  • dellwood333
Check out "ANY INFO ON SIDE STEPS ? " thread.
  • dellwood333
Or BTS Trading.
http://www.ebay.co.uk/itm/2008-CITROEN-B...2569c387ba
[-] The following 1 user says Thank You to j90xxx for this post:
  • dellwood333
(14-02-2013, 08:06 PM)j90xxx Wrote:  Or BTS Trading.
Look nice, but I would need the ones with the rubber step sections Smile
Complete with LED lights built in?
http://www.ebay.co.uk/itm/2008-CITROEN-B...RTM1319883
Ok, sorry, with steps.
Try this one.
Again, not cheap. Confusedillyme:
http://www.vanstyle.co.uk/shop/cobra-sid...tAodzhAA1g
Or here.
(Scroll down for steps.)
http://www.carbullbar.co.uk/acatalog/BERLINGO_2008.html
[-] The following 2 users say Thank You to j90xxx for this post:
  • dellwood333, ron
Simplest solution which works for me when I take my 90yr old ma-in-law out is a plastic caravan step.
If fitting side-steps....watch out for high kerbs !!!
(15-02-2013, 08:50 AM)Opensauce Wrote:  Simplest solution which works for me when I take my 90yr old ma-in-law out is a plastic caravan step.
Tried that as a solution, but the caravan step tend to be too high.
If the side steps do not work out as a viable option, I may have to make some sort of portable step from Marine ply & non slip material Smile
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
