  • 4 Vote(s) - 4 Average
Bingo just stopped
I hope someone can help my little bingo was running fine I started it up to move it then it just stopped I've plugged my diagnostic into it and its giving me pump module locked and a pertentiomoter fault I'm hoping someone can help as I need it for my business
You don't say what model it is, but take the oil cap off and check that the camshaft turns when the engine is cranked over. If it doesn't then I think you will have guessed the rest. Hope I'm wrong.
Hi, The only potentiometer I can think of is the accelerator pedal. :thumbsup:
Mine is a 1.9d I've already checked the camshaft turning that's all ok I wouldn't have thought it would have a pertentiomoter as the throttle is cable
Hi there, check the diesel pump lever as mine has a potentiometer on it so the ECU knows the throttle position. I have the 1.9 DW8B engine with Lucas pump though. The potentiometer will have three wires out of it going to a plug. Maybe of some help to you. Dave.
Smile it's already happened! Big Grin
[-] The following 1 user says Thank You to trader97 for this post:
  • Rustscrat
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
