  • 6 Vote(s) - 3.67 Average
Whistling noise ?
The old timer has developed a peculiar whistling/whining noise from under the bonnet this evening , which ceases completely if the clutch pedal is depressed . Any ideas ladies or gentlemen , the floor is open . . . cheers for any input in advance .
Probably the thrust bearing on the clutch, sounds like a new clutch may be around the corner.
Cheers for a prompt response dude , was only looking on your site a couple of nights ago , didn't think I'd be after your input so soon :eek:
I did suspect thrust bearing from limited knowledge but do not understand the implications , ie time to repair/replace or as you have suggested a brand new 2nd hand clutch :woop: gotta keep smilin it's only money :brickwall: bugger !
A new clutch is a lot better than used , probably cost you about £90 for the parts unless you find one on ebay.
I would NEVER fit a S/H clutch,it's not worth the hassle.
Repair properly,repair once.
Thank you both kindly , duely noted , new clutch only :thumbsup:
Incidentally , what would you knowledgeable types consider job time in hours would be ? as i know my local garage rate then I can work out the approx bill Confusedtudy:
Don't know what anyone else thinks but 5 hours would be tops... and most of that would be drinking brews and staring vacantly at diagrams... that's me any how! Smile
As Adam said,5hrs tops=3 1/2 hrs booktime+ siezed nuts& bolts etc.Oh the joys of being a motor mechanic.
So that's best part of a grand then ! the joys of not being a motor mechanic :eek:Wink
A Grand! Seems mental... are you going to the main dealer??
What's the quoted hourly rate for labour?
£500 would be a reasonable fee with top quality parts.
Make sure the oil is topped up/ changed in the gear box afterwards and there is no leaking present on the drive shaft seals.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
