Threads: 50
Thanks Given: 743
18-02-2013, 07:08 PM
(This post was last modified: 18-02-2013, 07:09 PM by Ol'Jeffers.)
Might be good to get us a photo to look at! An ID then would beforthcoming.
Is the wiring connected to the vehicle or lying free and disconnected?
The only things that are electrical and under vehicle seats are seat heaters,
pressure sensors for seat belts and electrical connectors for the airbag mechanisms.
If you have no warnings present on the dash it's not likely to be associated with airbags
or seat belts. It may have been discarded under the seat and is part of an accessory
which has been removed. So, you see, the list of possibilities is extensive and why
a photo would be useful!
Of course you could pop to a main dealer....it's possible that they might know what it is!
Threads: 81
Thanks Received: 397 in 340 posts
Thanks Given: 166
21
(18-02-2013, 06:59 PM)dellwood333 Wrote: Got my 2009 Berlingo VTR this afternoon & I am very pleased with it.
Whilst checking the Jack/toolkit position, I happened upon a plastic assembly, with wiring attached, lying under the driver seat.
Anyone tell me what it is & where & how it is attached - surely it isn't supposed to lie loose under the seat ?
Try uploading a photo
It sounds like the airbag wiring??
Threads: 50
Thanks Given: 743
I'm getting this strange feeling of de ja vous......Oh no! It's evdama!! LOLz
Threads: 50
Thanks Given: 743
18-02-2013, 07:20 PM
(This post was last modified: 18-02-2013, 07:21 PM by Ol'Jeffers.)
Come on all you Mk.III experts! What's the mystery item??
Threads: 67
Thanks Given: 1,045
I reckon it's supposed to clip under the seat "springs", and it's probably wire feeds for non-connected items like side airbags, seat heaters or adjustment motors.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Is it not for ventilation when you adjust the heater control to the floor?
I DO MISS MY BERLINGO
Threads: 81
Thanks Given: 166
21
This is the only wiring under the saet on my mk3
The snap is from the clutch pedal direction pointing out under the seat towards the door
[Image: fm18vl.jpg]
• dellwood333
