20-02-2013, 09:58 AM
last november my discovery died in a shower of rust on the mot ramp. i bought an 02 1.9 berlingo to replace it.. im running a lwb transit aswel. month or so ago the wifes picasso 2.0 hdi had to go into the garage with the engine management light on ....long story short mrs borrowed the berlingo and wont let me have it back. the picasso has had replacement injectors and other sensors and stillthe light has a mind of its own .... car will be ok for a week , then light comes on and it wont rev. fiddling with wires and fuses seems to make it go and next morning the light stays off .
bottom line is i dont really like the car... two a pillars makes a massive blind spot... the dash top reflects in the windscreen .... in sunlight the digital dash is too dim to see easily...needs half hour with the manual to work out which buttons to press to set the trip meter..... theres no key hole in the tailgate...means you have to walk round to a front door every time you want summit out the boot... and the tailgate was designed for short people you have to give it a push to raise it the last six inches.... forgrt and you get blood when you come back for the second lot of shopping bags.
do i buy a 2nd berlingo.? most of the other mpvs seem to have sloping screens that presumably will give the same dash reflection problems. but i want a tallish "estate" car.
kangoo, synergy or galaxy seem to be the other candidates . mpg and diy sevice and cost of bits are considerations
