Threads: 4
Thanks Given: 4
Morning All,
Driving into work this morning (Very cold and humid outside) I notice that a cloud of white smoke appeared from the exhaust whilst I was sat still and revved the engine. This happened when the vehicle was cold but also happened when I was nearer work (45min later) and it was hot (90'c on the temp gauge)
It is a 2008 Berlingo Panel Van with a 1.4 Petrol. It also has an aftermarket LPG conversion on if that makes a difference.
Any help as to what the cause is, is much appreciated.
I'm hoping that it is just steam from condensation in the exhaust/cold temps etc...but I suspect head gasket may be a cause.
Threads: 63
Thanks Given: 410
New Pope being announced ???? :whistle::whistle::whistle:
Threads: 10
Thanks Received: 57 in 36 posts
Thanks Given: 93
...after a Pole and a German, a pope from Brum!
The following 1 user says Thank You to CandR for this post:1 user says Thank You to CandR for this post
• andy-womble
Threads: 29
Thanks Given: 67
20
Every gallon of petrol or LPG you burn produces water, it's the hydro part in hydrocarbon and it accumulates in the exhaust then evaporates when you rev the engine. If you look at the exhaust when starting from cold you will see water droplets coming out in great quantities. It's nothing to do with your head gasket it's just basic chemistry. Check the oil and the water and if you are worried get the coolant tested at a garage for oil or fuel contamination but if you are not having overheating or pressurising the header tank problems you should just keep an eye on it and don't worry.
Threads: 63
Thanks Given: 410
(20-02-2013, 12:53 PM)CandR Wrote: ...after a Pole and a German, a pope from Brum!
I've heard that Ozzy Ozbourne and Lemmy have submitted CV's for the position....
illyme:
illyme:
illyme:
Threads: 29
Thanks Given: 67
20
It is more obvious in cold weather as the cloud of moisture hangs around for longer.
Threads: 4
Thanks Given: 4
Thanks for the support guys, I will feedback and let you know if it dissapears. The sun is shining now so it may be a little warmer outside.
Why do some cars do it more than others though, no-one else seemed to have this issue in the queue of traffic outside of work?
