  • 7 Vote(s) - 2.57 Average
Dashboard Switch Blank
Hi,
I have a 58 plate Bingo and whilst fitting a handsfree kit I found a spare cable + connector that goes to a circular switch blanking plate to the left of the steering wheel. It is simply clipped into the back of the blanking plate
Does anybody know what switch normally goes here? If I can get a switch will it activate a feature on my bingo?
It may be the cruise control connector.If you mean on the middle dash it could be electric window or A/C.
(21-02-2013, 08:30 PM)ron Wrote:  It may be the cruise control connector.If you mean on the middle dash it could be electric window or A/C.
It is just above the Headlight Beam adjustment if that helps?
Sounds like the location of the passenger mirror switch .
I think the above too! It's for the adjustment gizmo for nearside mirror.
On mine, the right hand panel housed the headlight adjuster and the mirror adjuster on the lower level, with 3 blanks above. From what I can see in the owners handbook, the blanks are for switches for the ESP and ASR systems when fitted Smile
Last Post: gitt
Today 08:27 PM
Not able to register
Last Post: Mike
Yesterday 11:03 PM
2011 B9 DPF warning light
Yesterday 10:51 PM
Last Post: Matt Haigh
Yesterday 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
