  • 4 Vote(s) - 1.5 Average
diesel problem..
hi all,when my berlingo gets low on diesel just aroud the reserve mark it starts to surge and cuts out and then its a pain trying to get to the petrol station.
if i dont let it get below say £10 in the tank theres no problem.
thought if it was the filter the prob would always be there..?
any help appreciated...KEV...:brickwall:
You have answered your own question dont let it get so low. You are probably sucking up air causing the motor to hesitate, do it enough and it will cut out plus you are picking up all the crap from the bottom of the tank.
worth draining the filter to see if theres any water or crap collecting there.... if there is it may be worth getting the tank drained out.
You may have a leak in the pick up pipe below which air from the tank is drawn.The previous tips are v good as well.
(23-02-2013, 08:30 AM)Tomcat3 Wrote:  You have answered your own question dont let it get so low. You are probably sucking up air causing the motor to hesitate, do it enough and it will cut out plus you are picking up all the crap from the bottom of the tank.
Bit pointless having a reserve warning light if you go below this level car doesn't work properly. Our 2.0HDi has gone v low (not proud of it just missed service station) and had no problem with pick up from the tank.
(23-02-2013, 09:58 AM)ricc Wrote:  worth draining the filter to see if theres any water or crap collecting there.... if there is it may be worth getting the tank drained out.
Doesn't the filter have a sensor for water? Not for crap though I guess.
(23-02-2013, 08:23 AM)KEVSPREAD Wrote:  hi all,when my berlingo gets low on diesel just aroud the reserve mark it starts to surge and cuts out and then its a pain trying to get to the petrol station.
when was fuel filter last changed?
£10 of fuel is not much these days is it! Sad
£10 is about 6 litres round here and that much fuel would not even register on the gauge. If you regularly run it this low you can almost guarantee that the problem is your fuel filter.
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
