  • 8 Vote(s) - 2.75 Average
Radio code
Music
Hi, I've just bought a T-reg Berlingo Multispace which came without Radio code or Handbook! In the meantime I've got the code from my local Citroen Agent (cost me 25 quid!) but am still clueless how to activate the radio. Any ideas?
You can usually get the code off Fleabay for a tenner or less...
To unlock the radio the usual procedure (not Pug/Cit specific) is to put down the driver's window, open the bonnet, then lock the car with your remote fob (with window down and doors shut) and disconnect the positive battery terminal. After this, have a cuppa. Some it helps to leave a full hour.
When you're done, come back to the car and reconnect the battery. Reach through the window and put the key in; turn on the ignition. Now unlock the door and open it.
With ignition turned on, the radio should prompt you with something like "Code" displayed on its screen. Enter the code provided using the preset numbered buttons; usually after the last number is punched in it will come spontaneously to life.
Rainbow
(23-02-2013, 12:21 PM)addo Wrote:  You can usually get the code off Fleabay for a tenner or less...
I tried this solution. In my case it didn´t work. Instead I had the ignition (driving) on AND the radio on for 15 minutes (the display said 5 ERROR) Then suddenly the four _ _ _ _ was shown and I entered the code, which I had for free from the company, that sold the car 10 years ago. In my case there were four numbers from 1 - 6.:woop: The radio played.
It used to be that if you put the wrong code into them 3 times it shut down for varying lengths of time leaving it switched on and ignition on ,dependant on the make then the four bars would come up for you to try again. After 3 times of shutting down it was supposed to lock and they could only be unlocked by the maker. A rumor going around was to put it into the freezer for a day then it would work whether the code was put in or not.Dont know if that worked or not never tried it.
sliding door panel removal
Last Post: mojito
Yesterday 07:35 PM
XL tyres
Yesterday 06:57 PM
Last Post: deejay_xb
Yesterday 10:06 AM
» Replies: 32
Unusual Braking Problem
Yesterday 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
