  • 5 Vote(s) - 3.6 Average
shutting electrics down when changing battery
Hi all, when changing the battery is there a correct procedure to follow, to shutdown electrics , just don't want to cause other problems, thanks.
Sort of; put the driver's window down then remove key and lock the car up after releasing the bonnet latch. Leave it a few minutes (say fifteen), then remove old battery and promptly connect new. If there's only a few seconds between old and new batteries you may well not lose the radio code (if fitted).
Once it's tightened down, reach in the window and put the key in the ignition, turn on. You should be good.
I connected a jump battery to the terminals before I removed them and left it on till they were refitted. No problem with BSI resets or anything and no waiting.
Rattling calipers
Yesterday 05:25 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
