  • 8 Vote(s) - 3.13 Average
overheating
just had temp gauge rise to red and stop light come on.lifted bonnet and it was bubbling away.What do i look for ?
Une nouvelle voiture? :whistle:
Y at-il d'eau dans l'huile?
(23-02-2013, 02:09 PM)greenfinger Wrote:  just had temp gauge rise to red and stop light come on.lifted bonnet and it was bubbling away.What do i look for ?
Hi there we will need a bit more info:
were the fans running
type of engine
mileage
age of vehicle
were you in trafic or moving - last time serviced
although we could point you in the right direction without this info it is much better to have the info for correct diag.
type of engine
mileage
age of vehicle
hi
its 2.0 hdi 03 plate with 58,000 on clock
it sounds like fan was running should the fan come on straightaway?
fan wasnt turning (just took it run round the block)
No the fans will only cut in when the temp gets to about 95.
if the fans were on and it still overheated like you described with the header tank bubbling it could be a sticking thermostat, head gasket or blocked radiator.
how far can you drive before it starts to overheat?
i had done about 6or7 miles before i noticed the temp gage had shot right up
i would say change the thermostat first - quite cheap and easy to get, right hand side of head looking from front of vehicle.
[-] The following 2 users say Thank You to polar for this post:
  • greenfinger, ron
Check your cooling liquid - In this time of year, I would look for frozen coolant blocking flow through the radiator.
[-] The following 1 user says Thank You to Drazen_R for this post:
  • ron
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
