Threads: 51
Thanks Given: 23
I'm about to change the glow plugs as I'm having difficulty starting. When I looked at them (to see how difficult it was) I noticed that there seems to be a leak from the rocker cover gasket. So I thought I might as well change that too. However...... Carparts4less (or Eurocarparts they're the same) list an upper and a lower gasket which seem to have different shapes. Are there really 2 gaskets? If not which one do I need?
http://www.carparts4less.co.uk/cp4l/c/Ci...ac0&000541
http://www.carparts4less.co.uk/cp4l/c/Ci...78d&000541
The leak (it's not a new one) appears to be just above the glowplug at the fuel filter/gearbox end of the engine.
Malc
Stupid computer!
Threads: 20
Thanks Given: 2,126
18
There's only 1 cover therefore only 1 gasket.All you need to discover is which one.Did you give VIN &/or reg no?
Strawberry flavoured windows
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
Is there a gasket , some do not have one , its just silicone sealer on them.
Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
i think there the same gasket just differant makers, they do this with most of there stuff.
Threads: 51
Thanks Given: 23
Looking at the Haynes book they mention an upper and lower engine cover and gasket so it looks like I need both, I suppose.
When I went to Eurocarparts I just used the Reg no. There isn't any means of searching via VIN on their site.
Malc
Stupid computer!
Threads: 67
Thanks Given: 1,045
There are two gaskets, inferieur and superior. Citroën only cater for the top one as a separate part; you need to buy an engine gasket set to get the both or a lower item. Nice work, if you can get it.
As per the pictures (hey, the internet is trustworthy, right?) your Febi one is the lower or inferior unit whilst the Rienze item is the topmost one.
Threads: 51
Thanks Given: 23
I'll have an investigate once I've got the airducting off when I change the glow plugs on Saturday. I was hoping not to have to spend too much money by buying extra gaskets.
Malc
Stupid computer!
Threads: 50
Thanks Given: 743
25-02-2013, 04:29 PM
(This post was last modified: 25-02-2013, 04:29 PM by Ol'Jeffers.)
Well that's a result then, bearing in mind that 'superior' gasket is cheaper than the
'inferior' alternative!
Threads: 51
Thanks Given: 23
(25-02-2013, 04:29 PM)OlJeffers Wrote: Well that's a result then, bearing in mind that 'superior' gasket is cheaper than the
:lol:
Malc
Stupid computer!
