Threads: 9
Thanks Received: 2 in 2 posts
Thanks Given: 6
Hi
2003 citroen berlingo 1,9 multispace
When i close the tailgate, it does shut and opens only when i lift the handle, but it will not lock either by the key or the central locking button, all other doors lock with the central locking, but not the tailgate. I would be grateful for any advice
thanks
Threads: 50
Thanks Given: 743
26-02-2013, 04:55 PM
(This post was last modified: 28-02-2013, 05:09 PM by Ol'Jeffers.)
If the lock appears to be operating but the tailgate doesn't
lock then it's likely to be a latch activating rod/lever/piece of damp French string(!)
which has come adrift inside the tailgate.
Hang around a bit for our Techie guys to give you the probable cause and what to do!
Threads: 32
Thanks Given: 13
Mine went but whilst still under warranty and as I recall it was a spring of some sort inside the mechanism.
Threads: 11
Thanks Received: 1 in 1 posts
Had this with both my berlingo's!!!
Theres a bit of wire that comes off, sounds a bit silly but i made a new one with a metal coat hanger, makes the lock a little bit harder to operate but works a treat!
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
There is a spring on the lock mechanism which moves the actuator away from the handle when the lock is turned. If the spring is missing it allows the actuator to remain in the unlocked position. I faffed about with other springs which didn't really work. Bit the bullet and bought a whole new mechanism which was £26 from the local peugeot stealer iirc.
Sent from my GT-I9100 using Tapatalk 2
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 9
Thanks Given: 6
Hi All
I will try and investigate the lock mechanism, is there
a video tutorial available or perhaps any diagrams etc
many thanks for your advice,
Tommy
Threads: 13
Thanks Given: 7
Its pretty straightforward. You need to remove the cover from the the recessed interior plastic handle of the boot. Undo the bolts underneath. You should iirc then pull be able to pull the plastic trim panel off. You'll be able to see the lock mechanism. Turn the key in the lock whilst watching the white plastic actuator. When you turn the key to the lock position you should see the actuator move away from the handle. When you release the key in the lock the actuator should stay away from the handle. If it doesn't then the spring in the mechanism has probably broken and disappeared.
alut:
Threads: 9
Thanks Given: 6
Many thanks for your kind advice!
Tommy
Threads: 67
Thanks Given: 1,045
Nifty and economical fix - good work.
• RolyG
