  • 6 Vote(s) - 2.83 Average
[Warning Light] Berlingo multispace Throttle setting fault
Engine management light on -Computer check indicates 2nd throttle position fault - New potentiometer fitted - fault not corrected:brickwall:[/size][/font]
I think you need to supply more info, What year and engine type, what code reader did you use and what codes did it bring up. A lot of code readers give you duff info the only one that works properly is lexia fom what I have read about it. Was the car running different to bring on the light.
(27-02-2013, 09:02 PM)Tomcat3 Wrote:  A lot of code readers give you duff info the only one that works properly is lexia fom what I have read about it. Was the car running different to bring on the light.
The fault is not with the instrument but the person interpreting the results, when looking up a fault code the art is in understanding what is wrong. A code reader for instance does not spell out "EGR valve needs replacing" so a lot of money could be wasted replacing parts that do not require replacing...
  • Rustscrat
I have seen one instance where a non-Lexia gave a fault code related to an LPG setup. On a diesel motor!
Have been banging my head against a wall elsewhere on the internet with a fellow who's got a blocked cat, and is constantly misreading the symptoms as causes. Amazingly (?) he's been that stubborn for almost a year and has replaced a bunch of unneeded stuff.
[-] The following 2 users say Thank You to addo for this post:
  • andy-womble, mikep1973
(27-02-2013, 09:02 PM)Tomcat3 Wrote:  I think you need to supply more info, What year and engine type, what code reader did you use and what codes did it bring up. A lot of code readers give you duff info the only one that works properly is lexia fom what I have read about it. Was the car running different to bring on the light.
Thanks- will check on code reader and post all details later
M59 1.4 Petrol question
Today 02:27 PM
Cold Starting
Last Post: jboy012000
Yesterday 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
