Threads: 2
Does anyone know anything about ECU's??. Need a new ECU,BSI and ignition key for my 2003 2.0 HDI, Mine has a Siemens set up,there are kits for sale online off vans the same as mine,but the part numbers are different,if they're off a matching van,would they work on mine??
Thanks in advance
Thanks Given: 188
23
Just a thought but why do you need all that lot has it been fried. There are firms out there that can repair program ecu and the bsi unit for you.
Are we there yet?????
Threads: 67
Thanks Given: 1,045
The ECUs can be unlocked, most quite cheaply (£50-upwards). That saves the need to code one in. BSI can also be virginised from a donor unit, and then coded to your car. If you just swap all that you will have mileage issues on the dash as well.
Threads: 50
Thanks Given: 743
03-03-2013, 07:08 PM
(This post was last modified: 03-03-2013, 07:10 PM by Ol'Jeffers.)
You'll lose nothing by sending your ECU and BSI to bba-reman.
They will sort it out for you and most likely when you get them back you'll be able to
fit them to the van and drive away.
(BTW I neither work for the above company nor do I know anyone who does. )
