Hi All
First post and all that! Have a 2013 crew van arriving next week to which one of the first jobs will be adding windows to the sliding door and rear quarter.
I know there a loads of firms that will supply and fit for around £300, does the glass/frame from older berlingos fit the 2013 or is it a new body shell ?
Also on the lookout for all the rear carpets/trim etc if anyone has any gathering dust.
thanks!
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
Welcome!
When you say 'older Berlingos' As far as your van is concerned I think
the furthest you can go back is 2009. The carpets on the Mk.III have the
underfloor storage boxes incorporated.....changing the carpets is a fairly
big job.
Before you do any of this work you would be well advised to check that none
of it would invalidate your guarantee. Citroen don't need much excuse to do that!
Threads: 76
Thanks Received: 332 in 275 posts
Thanks Given: 146
4
I had glass back doors fitted to my 2012 as a factory option - £150 ish with wash/wipe and heater included.
Warrantus Intacticus.
Im pretty sure the Citroen side windows didnt add up to much more either-but I didnt want to risk being liable for the 10% Car Tax as a result
Was there a special reason you are going the aftermarket route?
cratch:
You should be fairly safe with any MK3 windows -the back doors latching arrangement changed some time after 2010 but the panels shapes are all still valid
