  • 8 Vote(s) - 3.88 Average
Scratch
Other half rubbed the side of the car off a bus luckily not dented just scratched and pink paint! I've tried polishing it out but no luck.
I DO MISS MY BERLINGO Heart
[-] The following 1 user says Thank You to philip for this post:
  • taxi
You need to wetsand and buff; the clear coat is heavily abraded. Other option would be to blow a bit of clear over first, then bring up as above - it would just fill the scratches eventually.
  • philip
Remove the pink paint first using a paint restorer or scratch remover (NOT T-cut!). You may find with judicious elbow grease this will remove the lighter of the scratches too, but the worse ones will still probably need wetsanding with 2500 grit paper. Once the scratches are gone, use the paint restorer/scratch remover to bring back the shine to the area.
[-] The following 1 user says Thank You to FeuxLingo for this post:
  • philip
Always "the other half " eh Phillip!!!!Wink
Get some Farecla G3 scratch remover, good stuff and show her how to use it so next time you don't get to see it till after she's fixed it. Big Grin
(02-03-2013, 09:53 AM)FeuxLingo Wrote:  Remove the pink paint first using a paint restorer or scratch remover (NOT T-cut!). You may find with judicious elbow grease this will remove the lighter of the scratches too, but the worse ones will still probably need wetsanding with 2500 grit paper. Once the scratches are gone, use the paint restorer/scratch remover to bring back the shine to the area.
What is wrong with Tetrosyl Cutting Oil (T-Cut), Feux?
I have been using it for years.
Brought the (neglected) roof of my Berlingo up like I mirror (and still is, 2 years later).
Realise it is not what the Professional valeter or detailer uses.
Hasn't it recently won awards from 'Which? Magazine'?
My mate swears by mixing t-cut and coloured polish in equal parts.
Worked fine on a black car that I saw.
(01-03-2013, 05:43 PM)philip Wrote:  Other half rubbed the side of the car off a bus luckily not dented just scratched and pink paint! I've tried polishing it out but no luck.
Those Glasgow buslanes are dangerous places, Philip. :lol: ( only joking ).
http://www.t-cut.co.uk/index.cfm?page=56
(02-03-2013, 04:42 PM)taxi Wrote:  My mate swears by mixing t-cut and coloured polish in equal parts.
It happened on Union Street at 4pm rush hour!
The buses are mental down there !!!!!
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
