  • 4 Vote(s) - 3 Average
whats that noise?
Hi guys,
Had my berlingo for about 6 months now been running perfect up untill now, got a odd noise coming from the engine, can anyone help?
Iv got a 2005 Multispace 2.0 HDI coming up to 58000 miles.
Engine sounds normal when starting up and idle on drive, but when drive/accelerate I get what I can only describe as like a worbleing/wining noise. More noticeable able when take foot off accelerator with less noise from engine. happens when accelerating and decelerating and clutch in and out. Noise has got progressively worse/louder over couple of weeks.
Anyone got any ideas what it might be?
Crankshaft pulley rubbers perished, Just a thought?
(01-03-2013, 08:10 PM)brodfather11 Wrote:  Crankshaft pulley rubbers perished, Just a thought?
Thanks for the response I will take a look. Other than 'looking' what other signs would you see if it was worn? would it wobble when nudged?
Been for a spin with a mate who knows a little more about bout motors and thinks it could be a wheel bearing making the noise.
A wheel bearing is like a rubble jack up the offending wheel and spin it and listen and check for play by pulling/pushing top and bottom. For the pulley have a look around the area for black rubber dust and v small metal particales. There is a few threads on here about it.
Probably something that everybody else knows, but because of the double race used in these bearings, if you put weight on n/s wheel (turn right) and noise gets worse. this can mean that o/s bearing is worn on 1 side of race, found this out after replacing n/s bearing,input shaft seal and clutch,then gearbox complete and then o/s driveshaft support bearing finally asked mechanic in family who suggested other bearing. now silence is returned, still learned a lot along the way. just hope this might save someone else some stress!
Be interested if any one could tell reason why o/s bearing might last less than 10,000 miles.
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
[-] The following 1 user says Thank You to terryd999 for this post:
  • adamb87
The problem was the wheel bearing, sorted little while back only just getting round to pop it on here.
[-] The following 2 users say Thank You to Jimmyt3 for this post:
  • polar, RolyG
@ terry so this means that the normal way of checking the bearing goes out of the window. as i have just replaced one bearing ( near side ) and my noise persists. i know this is a few month old post but its an intersting find for me Smile
New Berlingo Anyone????
Last Post: msw109
Today 09:54 PM
multispace headliner
Last Post: big_chris88
Today 09:46 PM
Torsion bar
Today 09:17 PM
Berlingo----- Console
Last Post: Satellitemark
Today 08:53 PM
Partner 3 seat (front) conversion
Last Post: dumdum
Today 08:33 PM
How did the Berlingo get it's name ?
Last Post: Egg on Leggs
Today 07:07 PM
» Replies: 15
Tyres and suspension
Last Post: labeline
Today 04:35 PM
Aftermarket stereo wiring
Last Post: cancunia
Today 01:37 PM
2007 1.6hdi desire
Last Post: Rob.nixon
Today 10:32 AM
Seats
Last Post: kbracingdk
Yesterday 08:57 PM
