Threads: 8
Thanks Given: 16
Just getting used to my new Berlingo,sitting in car wtih hand book etc...have worked out onboard computer etc,but when it came to radio it would appear it only works with engine running, is that correct???Or am I missing some thing?Also kept getting message in display alternating between "Active" and "Economy"......would appreciate some knowledgeable advice thanks.
Threads: 63
Thanks Given: 410
Welcome, have a trawl around the forum. Plenty of stuff on this very topic. Have a looksy under <Economy Mode>
Threads: 78
Thanks Received: 363 in 306 posts
Thanks Given: 159
9
Radio should work independantly of motor-its a push on-off switch combined with a rotary volume adjustmnet
It will switch itself off after a frustratingly short time -"Economy mode"
This timing can be adjusted by a dealer or someone with a lexia device.
• caskin
