02-03-2013, 05:14 PM
So I went to change the glow plugs. Took of the air ducting over the engine etc. Fitted new plugs and reassembled. Engine starts refuses to rev and belches out loads of smoke. Hmm..... disassemble, refit old plugs and try again, seems better. Took it for a run, got about 400 yards and loads of smoke out of exhaust. Bugger. Give up and talk to garage as I've got MOT on Monday. Garage sensibly say, you must have fitted something wrong if it's suddenly got worse.
Start to disassemble then look at choke type thingy in intake duct (what does it do?) I find this is closing after the engine starts. If I hold it open the car runs ok. So then I find that there are two thin pipes coming from somewhere to the bottom of this choke thingy. Reverse the two pipes and all is well.
Hangs head in shame and shuffles away quietly :brickwall::brickwall:
Malc
Stupid computer!
Stupid computer!
