Threads: 2
Thanks Given: 1
I'm in need or a pair of roof bars for my 55 plate Berlingo Multispace Desire with Modutop, I've searched the breakers and eBay without luck.
If you can help, please drop me a line
Thanks :S
Threads: 50
Thanks Given: 743
What I think that Kiemadog is looking for are the OEM roof bars fitted to a Berlingo that has a Modutop fitted.
Very few and far between I would think. The only place to look really is the breakers and I would begin with the
online breakers as they have a network system. The other alternative is to bite the bullet and ask a Citroen
dealer how much! Depends how bad you need them. What I would do however is to screw in some bolts where the
bars attach to the Modutop so the holes don,t get full of moisture and begin to rust!
Threads: 51
Thanks Given: 23
It should be quite easy to molish some out of some ally or steel bar. It looks like it could easily be done at home.
Malc
Stupid computer!
