  • 7 Vote(s) - 3 Average
removing timing belt cover to change rocker cover gasket
hi guys, i have a 2.0hdi with a leaking rocker cover gasket. to change the gasket u need to remove the timing belt cover. But im struggling to get to the cover lowest bolt.
is there an easy way to reach this bolt to remove the cover?
cheers Chris.
Hi Chris, not sure about an "easy" way but generally if a timing area bolt is being difficult to reach one approach is to put a jack under the sump, and remove the offside top engine mount. Then you raise or lower the motor gently until the bolt or nut is accessible.
Remain wary of the fact your motor is on a jack; don't get under it or place you hand where it may be squashed if the jack slips away.
  • wiggers
(05-03-2013, 10:00 AM)addo Wrote:  Hi Chris, not sure about an "easy" way but generally if a timing area bolt is being difficult to reach one approach is to put a jack under the sump, and remove the offside top engine mount. Then you raise or lower the motor gently until the bolt or nut is accessible.
You may need to undo / loosen the lower engine mount to drop the engine, have a look before doing so just in case my memory fades :whistle:
  • wiggers
thanks guys. reached it by removing offside wheel. cheers for your help
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
