  • 8 Vote(s) - 2 Average
Timing Belt, Water Pump and Radiator
Morning All,
I have a leaky radiator, and need the timing belt (+waterpump) changing on my Berlingo 1.4 petrol.
I have had a finger in the air quote from the garage of £400 to £500 to do the whole job. Is this reasonable?
How difficult is it to do the job myself? Can it be done by following a haynes manual?
(06-03-2013, 11:11 AM)Dingbat46 Wrote:  Morning All,
Hi, i think its ok on price changing timing belts with out the right tools is not a good idea, get it wrong and the engine is damaged but you can change the rad ok new one around £90.00. jre
Just another question, would the 206 engine be the same as I have in the Berlingo and therefore would this guide be appropriate? http://www.eastment.net/206cb/index.htm
It's basically the same motor, make sure you get the correct belt kit as there are two lengths/tooth counts of belt and with them come different tensioners and water pumps. This all changed mid-2000.
A Nissens radiator will often be the cheapest of "name" brands.
See comments elsewhere on the forum about jacking the motor up or down to access certain bolts to its offside.
  • Dingbat46
(06-03-2013, 12:24 PM)addo Wrote:  It's basically the same motor, make sure you get the correct belt kit as there are two lengths/tooth counts of belt and with them come different tensioners and water pumps. This all changed mid-2000.
Thanks, is there any way of knowing without stripping them off the engine first? It is a 2008 Berlingo if that helps?
It can be read off the motor's serial number on the block front, however being 2008 I would say confidently yours is the later type timing kit.
(06-03-2013, 12:30 PM)addo Wrote:  It can be read off the motor's serial number on the block front, however being 2008 I would say confidently yours is the later type timing kit.
Thanks! Now to just find a free weekend to do it!
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
