  • 5 Vote(s) - 2.8 Average
[Engine] berlingo starting dead
Hi i am John and i have a Berlingo van year 1999 with a 1.9 litre WJZ engine the van with well for 4 years then yesterday it would not start
i have check over engine heaters, fuel to pump and all the things you would say standard faults. on cranking over no fuel to injectors os i guess its a immobiliser fault, my van has a transponder key no button on key i have only i key and no code number.
So can i test my key to check if working also can i wire in new live to injector stop switch, the injector pump is not controlled by a ecu on this model only the engine stop and advance correction solenoid also where can i can a wiring sheet forthis van.. help
Are you sure the cambelt is OK? That's the first item to check.
  • johnny
Video
(06-03-2013, 12:17 PM)addo Wrote:  Are you sure the cambelt is OK? That's the first item to check.
Hi thanks for input i changed timing belt two years ago but will check
again the engine turned over sounded right. john
Hi addo,
I have rechecked cam belt and all looks ok i have four compressions on turnover of engine i could remove covers hmm
(06-03-2013, 11:31 AM)johnny Wrote:  Hi i am John and i have a Berlingo van year 1999 with a 1.9 litre WJZ engine the van with well for 4 years then yesterday it would not start
Checked the glow plugs already?
A Testing Question....
Today 03:53 PM
Wheel nuts
Today 10:16 AM
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
