Rear Calliper
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Went out to work last night and had just finished 1st job and a peeping sound but no warning lights, it went off after a few seconds so I thought a door was not closed, checked them and were all ok. Sat for about 10mins then got 2nd job of the evening and then peeping sound again and STOP light comes on intermittent. 5 mins later peeping, STOP light and brake warning light stay on. I dropped off customer and then checked the brake fluid, it was empty!
This afternoon I jacked up the car and noticed its leaking from the off side rear calliper.
Im hoping £150 will fix it.
I DO MISS MY BERLINGO
The following 1 user says Thank You to philip for this post:1 user says Thank You to philip for this post
• taxi
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Ouch ! Scary stuff.. Hope it's not as bad as you think.
Former 2011 Mk3 XTR owner  alut:
Threads: 63
Thanks Given: 552
(09-03-2013, 07:33 PM)taxi Wrote: Ouch ! Scary stuff.. Hope it's not as bad as you think.
Thanks!
Threads: 96
Thanks Given: 709
Make the most of your enforced weekend off.
The following 1 user says Thank You to taxi for this post:1 user says Thank You to taxi for this post
• philip
Threads: 50
Thanks Given: 743
Don't take it to a Main Dealer then! They'll charge you that to change the brake fluid!
Sounds like calipers died. May be the brake was binding and the excess heat damaged the seals.
Threads: 63
Thanks Given: 552
(09-03-2013, 09:04 PM)OlJeffers Wrote: Don't take it to a Main Dealer then! They'll charge you that to change the brake fluid!
Funny you should say that I could smell a burning a few nights ago.
I'm taking it to my mates garage Citroen Glasgow now charge just to look at a problem £44!
Threads: 67
Thanks Given: 1,045
If it's just seals, shouldn't be too hard to sort. Was it leaking from the butt end or around the pads?
Threads: 50
Thanks Given: 743
Seized piston Adam? I'm more used to that on bikes!
Threads: 67
Thanks Given: 1,045
It's a fairly old-school caliper by the looks of it (I checked out the Budweg exchange units). What I've found often happens to PSA rear calipers is the piston or bore corrodes behind the dust boot, ahead of the square section seal - this jams the piston in nice and tight. Then you put an uncommonly heavy load in the back and it opens the compensating valve; application of hard braking pushes the piston out just enough to work, but it doesn't retract. The "dead leg" of water-filled brake fluid then boils as it's blocked against returning by the load compensator and/or a collapsed flex hose, either pushing the brake pad on harder or blowing out the handbrake lever seals.
On some calipers, winding back the piston without cracking the bleeder, similarly blows out the handbrake seals - Xantias are good for this.
Threads: 63
Thanks Given: 552
(09-03-2013, 11:02 PM)addo Wrote: If it's just seals, shouldn't be too hard to sort. Was it leaking from the butt end or around the pads? From the back.
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
