  • 17 Vote(s) - 2.12 Average
New Berlingo - first pic
I've had my current Berlingo for almost 3 months, and have finally taken a picture. It's not great, but I'll try* to post it anyway, and get something better another day.
It will also just about do as an avatar until I get something better.
[Image: Berlingo2resize.jpg]
*And if you can't see it, don't worry - nor can I. I have yet to succeed in uploading a picture to this forum which has not required a moderator to come and sort it out.
You'll be able to see it at: http://s38.photobucket.com/albums/e107/B...resize.jpg
Got it to show for you
Lliam
70 plate Berlingo
Thanks. I knew you be along soon to help!
For future reference:
Code:
[img]URL TO IMAGE HERE NO SPACES[/img]
Back on topic, nice ride Smile
Thanks, Andre.
Of course, it will not work when I try it. Smile
And I'll prove it.
Edit: Got it now - thanks to lemsworld!
[Image: Berlingo2fromfront.jpg]
Where did you get your image code from?
Lliam
70 plate Berlingo
Between [img] & [/img], I simply inserted:
http://s38.photobucket.com/albums/e107/B...mfront.jpg
It's what I do every time, and it never works for me. It's the same when I click on the "Insert image" icon.
I've tried the "Add attachment" route to adding a jpeg. It didn't work last time, but I'll try it again.
Edit: Oooooh! It worked this time!
Attached Files Thumbnail(s)
Did you copy this from the web bar at the top?
Lliam
70 plate Berlingo
Quote:Did you copy this from the web bar at the top?
Yes.
They give you a HTML code for it to be copied and pasted as the one at the top is for a page not just the image. I'll get some screenshots to explain, need the laptop off my girlfriend first
Lliam
70 plate Berlingo
[-] The following 1 user says Thank You to lemsworld for this post:
  • Northman
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
