Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
hi can anyone tell me if the rubber trim that along the side of a multispace 04 (some are black and some are colour coded ) are they stuck on ? thanks
Threads: 20
Thanks Given: 2,126
18
I would have thought they were stuck on.The manufacturers tend to use the cheapest method.Try prying gently the panel concerned,using a wide lever & protecting the paint underneath(on the panel).Good luck.
Strawberry flavoured windows
Threads: 67
Thanks Given: 1,045
You mean the exterior moulding? If so, it's held on with eight or ten push plugs in small plastic sockets.
Threads: 43
Thanks Given: 3
cheers addo thats good to know i managed to put a bit of a dent in the rear side door nothing much but its anoying me. so ill find another door the reason im asking is because a lot of the cars have black trims and mines silver. i thought that they would be stuck on so thats good.
Threads: 50
Thanks Given: 743
If the dent is small, surely it would be cheaper to get someone like Dent Doctor to do it.......
Thanks Received: 22 in 16 posts
Thanks Given: 36
Does anyone know how to get these exterior door trims/rubbing strips off without damaging the fixings or trim as I have a 2014 XTR and want to colour code the black trims as they are on the VTR? Thanks.
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
