  • 9 Vote(s) - 3 Average
Alternator/battery dash light on
Occasionally i get this light, tested, really doesnt charge when alt light on.
car has 80K miles.
alternator probably OK.
Been told it could be regulator in the engine bay. Where exactly can i find it.
Most alternators have the regulator inbuilt; on many it can be changed without dismantling the entire unit. There's a choice of OEM and Chinese parts for many electrical repair items.
by expirience, could i just lift car, tuck under and remove the regulator from alternator, or is alt removal obligatory
It is much easier off the car, even when the alternator has an externally accessed regulator. Some cases you cannot replace it without removal. What brand of alternator, and is there a label on it?
Needed some time to lay under in take a pic.
Says made in spain also.
Attached Files Thumbnail(s)
It's a Bosch one, the 0124525034 part number is a sign.
Here's one supplier's part listings for this model:
http://www.woodauto.com/Unit.aspx?Man=BO...0124525034
They seem to usually supply aftermarket (non-OEM) parts.
  • dwr400
Alternator removed.
But problem is how to split it?
Removed all visible bolts and nuts, except the pulley and small 4 surrounding philipses.
Dont need breaking stuff while rebuilding Smile
while it being pain in the back to remove and install, only faulty regulator was to blame, so a quick fix.
Signs of deterioration were present, but was not aware of.
Alternator light should cut out instantly after start, not with half sec delay. Also it should charge 14.3 - 14.4V measured on battery, mine was 14V prior to fix, maybe less in last days.
Many small problems now fixed. Non perfect starting, occasional erratic idling, power delivery, even though souped to 110hp. But problems showed very subtle, now ok.
Update to the topic.
Renewed alternator lasted less than a year. I got the dash battery warning on again.
When repaired, I used original bosch regulator.
I presume it is toast again.
What should I blame for messing the regulator in such short notice?
solved again.
stator connections to the diode plate got loose.
re pressed and soldered.
[-] The following 1 user says Thank You to dwr400 for this post:
  • Rustscrat
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
