Threads: 3
where is the rear interior light switch located for loading area? It works when i move switch on light to perm but does not work on door mode.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
Behind the drivers seat on the offside there is a connector block which is prone to corrosion. It is under a plate which is held in with 4 torx screws. Between the rear wheel arch and the door pillar. The wire which goes to the door switch for the rear light runs through it, remove the plate and remake the connections and it should work.
:thumbsup:
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
The door switch is part of the latch/lock mechanism.
