  • 5 Vote(s) - 2.6 Average
Central LOcking
Central Locking (1.4L petrol MPV)
I am having trouble with remote control central locking (CL). My vehicle is special import into Australia (wheelchair access conversion). Not a lot of Berlingos here with CL so little local info.
Problem is CL unlocks itself after vehicle is left for a time – sometimes hours sometimes days.
I notice that there is no mechanical switch on doors to activate internal lights so the “door closed” sensing must be in the actual door lock. I suspect that one of these sensors might be the problem as a couple of times with all doors closed the CL has not latched. Opening and closing doors once has immediately allowed CL. Can anyone tell me where the “door closed” sensors are located and whether there is any adjustment? Bought manual but its not helpful.
The other curious thing I have noticed is the behaviour of the rear hatch door. This locks/unlocks using the remote in sync with front doors. Also locking /unlocking front door with key also locks/unlocks all other doors and hatch as normal. However the rear hatch can be unlocked using the key, independent of the front doors (which will remain locked). Curiously if the hatch is then opened (swung up) when it gets approx horizontal the CL triggers and unlocks all doors (audible clunk). I don’t know if this is supposed to happen (does not seem logical) or it is a fault. I am thinking if it’s a fault there may be a wiring problem that is activated by the hatch swinging up - loose wiring falling inside hatch or wiring being strained by the hinge action of the hatch? If so this might be related to mysterious CL intermittently unlocking.
Appreciate any advice whether this is normal behaviour and where/how “door closed” sensors are on front doors and hatch.
Both front doors have "master" locks in them, in the sense that locking either with a key will command the whole system to lock. Not so for other doors. The lock assembly itself, also provides information to the BSI that allows it to control interior lighting. In case you need to replace either, note they are the same as front door locks from Series 2 Citroën Xantias and many Peugeot 406 models.
Probably what is happening re the rear tailgate and lighting/unlocking is that you have a tilt switch in the tailgate and when it's triggered the BSI gives a command to unlock the whole car.
Stored in your car's fault log, will be reference to which of the front door locks is intermittently faulty.
(14-03-2013, 08:00 AM)addo Wrote:  Both front doors have "master" locks in them, in the sense that locking either with a key will command the whole system to lock. Not so for other doors. The lock assembly itself, also provides information to the BSI that allows it to control interior lighting. In case you need to replace either, note they are the same as front door locks from Series 2 Citroën Xantias and many Peugeot 406 models.
Had the same problem with my 02 2.0 HDI. there is a microswitch type thing in the door catch mechanism that goes wrong, it is a new lock as they are not servicable (fault codes should identify the correct one) IRC that fuse 21 (please check the hand book) supplys this circuit, i removed the fuse and have reverted to "mandraulic":whistle: locking (push the door buttons)
Thanks ADDO for info
How do I access the fault log? I assume its a laptop plug-in to the system? If so I could be in trouble to get anyone in Melbourne to access it?
Regards
M59 1.4 Petrol question
Today 08:47 AM
Today 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
Yesterday 06:47 PM
Last Post: deejay_xb
Yesterday 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Yesterday 01:48 PM
Unusual Braking Problem
Yesterday 07:52 AM
valeo alternator CL15 rebuild
Yesterday 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
15-03-2025 04:34 PM
