  • 3 Vote(s) - 2.67 Average
Air bag warning leg
Hi
Got a 54 plate 1.9 berlingo and when I was driving to work the air bag warning light came on. Will have a look at the weekend but anyone had this problem or know what it could be?
Cheers George
(14-03-2013, 08:42 AM)GEORGEMXR Wrote:  Hi
Cheers George
There are two cable plugs under both front seats (if you have passenger airbag), that are somewhat glitchy. Bad wiring, i guess. Had this problem ever since i bought the car brand new. I've read that if you reconnect the wires yourself it'll go away, but I guess I'm too lazy. So what i do is move the seat(s) a few times with the engine off, screw around with the cables a bit, then turn the ignition key on and check if the warning light will go out. Rinse and repeat Smile Sounds a bit annoying, i know, but if the problem isn't too serious it'll work.
Got in to go home and the light never came back on so will see how to goes
Cheers
You could just put a short in the plug under the seat (assuming it's a normally open switch).
Malc
Stupid computer!
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
