Threads: 9
Thanks Received: 1 in 1 posts
Thanks Given: 2
Before I give any info on my problem can someone tell me what sort of symptoms I would get on a dw8b engine when the needle lift sensor is not working?
Thanks again in advance everyone.
Threads: 61
Thanks Received: 712 in 609 posts
Thanks Given: 210
49
Probably this ... black smoke/loss of power/limp mode etc ......anywhere close ???
Serieal Berlingo owner
Threads: 9
Thanks Given: 2
23-03-2013, 05:15 PM
(This post was last modified: 23-03-2013, 06:59 PM by daz3nt.)
Ok I've replaced the injector #1 and plugged in the needle lift sensor but it still sounds like a bag of spanners inside a washing machine. Does it need to be reset first?
Also I found that the vacuum pipe is broke on the egr valve. Would that cause any problems?
Berlingo 54 plate
1.9d DW8 engine.
Quick edit: just started it up and it run really smooth for the first 5 seconds, then reverted back to a bag of spanners. Someone please help me :-(
Threads: 9
Thanks Received: 2 in 2 posts
Thanks Given: 15
24-03-2013, 01:36 PM
(This post was last modified: 24-03-2013, 01:44 PM by trx.)
Have a look in mk1 section Daz i have the same problem with my 1.9d its under Diesel misfire and where to start could be your advance solinoid on the pump.
Dave
Threads: 9
Thanks Given: 2
Wrong type flywheel. No pickup. I've opened a new thread to try and get around this problem without having to remove the gearbox.
