  • 5 Vote(s) - 3.4 Average
Rear light connections
Got a high level brake light out of a partner van to put in my berlingo. I made a note of the number of the connectors the two wires need connecting to 1&2. Will these be the same on the berlingo???
They should be, year for year at least. You may well find the plug is tucked into the door shell, ready and waiting.
With that in mind I thought I'd check the light by removing the connector and connecting straight in to test it, nothing! However, I may now have found my brake lights don't work??? Wonderful, is there a seperate fuse for each side or one for both as neither are working!!
I think both brake lights are on the same fuse.
At least you found out the safe way - rather than having someone collide with the back of your car.
Maybe .... Just don't know if they where working before which is the worry.... Also as I don't have a fuse diagram for it 2001 plate .... I have to mess with all the fuses now
Can't find an obvious fuse blown, but its started to snow.... So only check 5a fuses
Have a look at the brake light switch up on a bracket above the pedal. It may be broken or stuck. Check it with a meter and and the wiring to see if lights come on.
My money's on the brake light switch, too!!
mine was the switch, about a tenner from main dealers, really easy fix
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
I'm thinking that ... Fingers crossed ... Stuck at work till weekend though
Now tried the switch... but still nothing ... any thoughs
Realising I posted this in the wrong place really, I've sort of moved it across to the right place!
Side Light Bulb Holder
Last Post: Starkebab
Today 10:52 AM
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
