Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Been trying to find answer to this on forum but cannot locate it.
Is it ok to jump start another car using Berlingo Multispace, or can it corrupt / damage BSI ?, thanks in advance.
Former 2011 Mk3 XTR owner
alut:
Threads: 32
Thanks Given: 13
I've done it loads of times... heard it said it can be a problem, but never heard anyone have anything go wrong before.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• taxi
Threads: 24
Thanks Received: 80 in 59 posts
Thanks Given: 6
Well, I tried it and couldn't get it to work. Never figured out why and used the other car instead. Didn't hurt the Berlingo mind...
Threads: 67
Thanks Given: 238
50
It is ok to do so .........
connect +ve to + ve
connect the -ve of the " donor " battery to a decent engine earth point on the receiving car.
Serieal Berlingo owner
• taxi
Threads: 15
Thanks Given: 46
5
On the Mk3 'lingo there appears to be a circular metal thingy screwed to inside wing to the right of battery. I'm guessing this is for the - lead with + lead on battery as only + terminal is accessible.
The following 1 user says Thank You to Opensauce for this post:1 user says Thank You to Opensauce for this post
• taxi
Threads: 29
Thanks Given: 67
20
I've started my friend's Seat diesel with my Mk2 Berlingo. Connect as above then run the Berlingo engine for 10 minutes without trying to start the receiving car to put some charge into the battery before you try to fire it up.
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• taxi
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
I started my sisters Saab with the Berlingo last year and hasn't done any damage.
I DO MISS MY BERLINGO
The following 1 user says Thank You to philip for this post:1 user says Thank You to philip for this post
• taxi
Threads: 13
Thanks Received: 43 in 34 posts
Thanks Given: 11
(22-03-2013, 03:13 PM)ffrenchie Wrote: I've started my friend's Seat diesel with my Mk2 Berlingo. Connect as above then run the Berlingo engine for 10 minutes without trying to start the receiving car to put some charge into the battery before you try to fire it up.
Brother in Law works for the AA and this is exactly what he said to do when we asked. I recalled reading something about jump starting other cars in the handbook and checked after a friend got stuck.
The Bus II: 2019 XL Flair 1.2
