Threads: 21
Thanks Received: 4 in 4 posts
Thanks Given: 16
hi
2.0 hdi
decided to get a new battery as mine is on its way out...so ive looked at a couple of places...
two batterys were recommended
type 100 and 027
the 100 type is larger and has higher output but i was told i didnt need that one???
any recomendations
Threads: 52
Thanks Given: 87
5
I always get the highest capacity battery that will fit the mounting area. Recently replaced my original Tudor with a VARTA Silver Dynamic E44.
Threads: 20
Thanks Given: 2,126
18
I agree,fit the biggest you can.It will also last longer due to less stress.:thumbsup:
Strawberry flavoured windows
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Correct, and correct.
I have a big one.
( And a high capacity battery, too. :woop: )
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• addo
