Gears / clutch
Threads: 30
Thanks Received: 99 in 44 posts
Thanks Given: 40
4
Here's the problem:-
When trying to put the gear into 1st it can be tough, no crunching just won't push in. It does eventually though
Don't know much about it but here's the type of answers I got but which one could it be or maybe a different answer
1. Linkage
2. Gearbox oil
3. New clutch
Any help would be appreciated
Thank you
Lliam
70 plate Berlingo
Threads: 52
Thanks Given: 87
5
Curious, that happened to me yesterday. Had killed the engine at a stop sign, restarted and I could not get it into 1st to save my soul. After a number of tries (horns honking at the old fart) it went in, no grinding, just difficult. After that all is fine again.
Threads: 32
Thanks Given: 18
Did double clutching make it easier?
I did a how to on changing gearbox oil, it's a pretty simple task;
http://www.berlingoforum.co.uk/showthread.php?tid=457
Thanks Received: 6 in 4 posts
02-04-2011, 09:38 AM
(This post was last modified: 02-04-2011, 09:42 AM by dvil.)
Hi,
New here, looking for info regarding changing clutch.
On your problem; I would suspect the clutch wire. It has a selfadjustment feature that sometimes slip. Sounds like your clutch didn't release properly. The wire readjust everytime you push the pedal (or maybe every release).
We realized "pedaltothebottom" in afternoon traffic in a tunnel under Oslo, made a real trafficjam. Thought the wire broke, but after getting the car home we saw that just lifting the pedal by hand fixed the whole thing. :eek:
After driving a while with the wire more and more often slipping, I replaced the wire (painintheassjob). At first startup weird noises came, and I now have a complete clucht failure. Small balls from the releasebearing falling out, and the realese arm sticking out in a weird direction. :brickwall:
By the way; this looks like a great forum. Thanks.
2004 Bingo 2,0 HDi MultiSpace. In Norway
Threads: 147
Thanks Given: 263
11
Thanks for the info dvil. :thumbsup:
Threads: 52
Thanks Given: 87
5
Thanks dvil. Sorry to hear about your problems.
Threads: 7
Thanks Given: 2
Dvil, our member wimpy is also from Norway!
Thanks,
Lot's of Bingos in Norway, but mostly clean workcars.
Mine was bought in a hurry because it was cheap, but I really like it. Well, not right now...... :blackeye:
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
03-04-2011, 02:30 PM
(This post was last modified: 03-04-2011, 02:34 PM by pk7478.)
(01-04-2011, 11:29 PM)lemsworld Wrote: Here's the problem:-
1. Linkage
2. Gearbox oil
3. New clutch
Thank you
Lemsworld.
It can be:
1. Clutch cable
2. Rusty joints of selction mechanism.
(02-04-2011, 09:38 AM)dvil Wrote: Hi,
It's a "desease" of all M59, especially after commercial usage.
Threads: 30
Thanks Given: 40
4
Thank you pk and dvil. How do you check/ change these? any tips?
Thank you
Lliam
70 plate Berlingo
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
