Display
Threads: 11
Thanks Given: 1
Hi, On my Mk3 Berlingo, in the centre display there is a reading which normally shows me average mpg. Suddenly that has dissapeared, and a message saying 28 MPH, and a symbol of a car with an arrow pointing to the right. What does this mean, how can I get the old screen back please ?.
Badger
Threads: 67
Thanks Given: 1,045
That may be either the cruise control preset speed, or average road speed when moving. What happens if you press the stalk tip on the right while the car is idling?
Threads: 81
Thanks Received: 395 in 338 posts
Thanks Given: 165
20
30-03-2013, 12:06 PM
(This post was last modified: 30-03-2013, 12:10 PM by evdama.)
Ditto addo
Thats advising of your average speed on base models without CC.
The button on the end of the longer of the two stalks on the right of the steering wheel.
Usually holding this down for around 5 seconds when stationary resets (ALL)the data in the display.
Threads: 11
Thanks Given: 1
(30-03-2013, 11:13 AM)badger Wrote: Hi, On my Mk3 Berlingo, in the centre display there is a reading which normally shows me average mpg. Suddenly that has dissapeared, and a message saying 28 MPH, and a symbol of a car with an arrow pointing to the right. What does this mean, how can I get the old screen back please ?.
Badger
Thank you very much you were quite correct. Pressed the stalk to scroll through display options.
Badger
Threads: 15
Thanks Given: 46
5
With display set to average mpg, press & hold stalk to zero this, ie measures average mpg from that point on. Useful if you want to find average mpg separately for motorway trip or just around town etc.
The following 1 user says Thank You to Opensauce for this post:1 user says Thank You to Opensauce for this post
• addo
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
I reset every time I fill up. Current Average MPG is good for adjusting speed etc to conserve fuel.
Former 2011 Mk3 XTR owner  alut:
Threads: 81
Thanks Given: 165
20
A difference from my '10 plate to this '12 plate is that Ive gained an additional tripmeter on the display.
The stalk button scrolls between the current running totals (Speed mpg range etc) to two separate trip-total positions.
They often read identical figures but i havent had the need to use both so far,
Threads: 2
Thanks Given: 1
(30-03-2013, 03:31 PM)badger Wrote: (30-03-2013, 11:13 AM)badger Wrote: Hi, On my Mk3 Berlingo, in the centre display there is a reading which normally shows me average mpg. Suddenly that has dissapeared, and a message saying 28 MPH, and a symbol of a car with an arrow pointing to the right. What does this mean, how can I get the old screen back please ?.
Badger
Badger
Hi , I had this problem and the advice given sorted the screen out , many thanks .
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
(30-03-2013, 06:25 PM)evdama Wrote: A difference from my '10 plate to this '12 plate is that Ive gained an additional tripmeter on the display.
Does that mean you have 3 trip meters? I got 1 above the total miles and a trip meter on the big display in middle of dash.
I DO MISS MY BERLINGO
Air filter box removal
Today 12:47 PM
Berlingo undertray
Today 12:42 PM
» Replies: 21
Yesterday 10:10 PM
» Replies: 21
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
