Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
I topped up the brake fluid today in the Berlingo, I used Comma DOT4 from Asda £3 for 500ml. I never knew until I had topped it up on the back of the bottle it says do not use with Citroën and states other car makes, have I used the wrong fluid?
I DO MISS MY BERLINGO
Threads: 67
Thanks Given: 1,045
No, they mean don't mix it with LHM.
DOT4 is the right stuff for your application.
Threads: 63
Thanks Given: 410
Usually says on the cap to the reservoir,master cylinder...
Threads: 51
Thanks Received: 35 in 32 posts
Thanks Given: 3
I use 5.1 myself. Costs same why not
Halfords 8 euro for a litre bottle
Threads: 16
Thanks Given: 46
5
The 'not Citroen' bit refers to the hydraulic suspension on older cars, I think.
Threads: 29
Thanks Given: 67
20
(01-04-2013, 01:24 AM)corkgsxr Wrote: I use 5.1 myself. Costs same why not
It's no advantage so why bother ? Unless you are draining your old fluid and completely replacing it you are not gaining anything but Super dot 4 is actually higher rated than some cheap dot 5.1 fluids.
